Home > Maintenance & Mods (L322) > 3.6 turbo replacement
Page 2 of 3 <123>
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Very interesting
Good luck with the other turbo.
Please post your findings again if you don’t mind 2007 3.6 TDV8
Post #471887 10th Mar 2018 6:22am
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Due to lack of time I’ve had to give up on this as a diy job and pay someone it’s going in one day this week as soon as I organise transport , after removing the turbo to intercooler pipe I drained about 300mls of oil out of the hose and intercooler so the right hand turbo is definitely knackered , the other one is probably ok but I darent risk it so getting them both replaced.
Post #472114 11th Mar 2018 12:37pm
birchyman71
Got the car back from the garage , he did both turbos replaced with recons with a 2 year warranty for £1740 , the right hand one the oil seals had gone and the left hand one was about to fall apart so on the bright side it didn’t and as I just turned the car off and didn’t attempt to run it he says I probably saved the engine , don’t know how but he did them both without dropping the diff or subframe , on another point the day after I got it back the rear right side dropped over night but the car though it was at extended height so wouldn’t raise up after a look round found the front left height sensor plug had a snapped wire !! New plug from landrover dealers was only £9 chopped the old one off fitted the new one and faults cleared themselves , looking forward to a few months of trouble free motoring just got the rear brakes ( discs and pads and shoes) to do and change all the diff and transfer box oils , sort out the rusty arches and it might get through another 150k miles.
Post #474343 30th Mar 2018 12:17pm
rar110
Thanks for the update. That sounds like a good outcome. ______________________________
Post #474345 30th Mar 2018 12:24pm
cheezels
That’s good news (but bad for Ye olde wallet though)
The jobs you mentioned are a walk in the park compared to what you’ve been through 😀
Just out of bi curiosity, did your chap have any suggestions as to why the seals failed? 2007 3.6 TDV8
Post #474346 30th Mar 2018 12:32pm
Rich_Allen
Someone on one of the Facebook sites who is a HGV mechanic has just done his...
4 hours to remove both turbos on the floor with just a jack... he did the drivers one in 53 mins...
so it’s definitely doable! 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #474377 30th Mar 2018 6:23pm
gt40
South Africa 2011 Range Rover Vogue SE TDV8 Zambezi Silver
Do you have any more info or a link to this Facebook site? I replaced both turbos on my 2010 around 6 months ago and it was a nightmare.
I have to do my other car soon and would love to get some tips and shortcuts.
Post #474384 30th Mar 2018 7:29pm
Rich_Allen
Won’t let me share but it’s on the Range Rover Mk3 - L322 page.
Poster is Maxwell Williams. Should be fairly easy to find 2008 TDV8 Vogue SE
2002 TD6 Vogue
Post #474391 30th Mar 2018 9:46pm
Mikey
4 hours to remove, not to replace?
Post #474588 2nd Apr 2018 8:26pm
Roger3
South Africa 2008 Range Rover Vogue TDV8 Java Black
Did you manage to find the site or link, tried searching but nothing.
ps how are your turbos holding up, looking a redoing mine next week.
Post #520523 3rd Jul 2019 4:53pm
gt40
Unfortunately I did not find the info.
My turbos are doing fine. I had them overhauled by a Turbo specialist in Cape Town and no problems so far. I have another TDV8 that needs turbo work but I intend to remove the engine to do the job as it also has a broken exhaust manifold bolt which seems to be impossible to replace in situ.
PM me if I can be of any assistance.
Post #520527 3rd Jul 2019 5:24pm
Roger3
Thanks GT40
I'll poke around in the dark until I make progress, will be slow but that's best anyway.
Did you remove the turbos yourself or did the specialist do it all? if they did, do you recall if they dropped the subfame? 2008 L322 TDV8 Vogue
2004 Discovery 2 ES TD5
2002 P38 Vogue SE V8 lpg
1998 P38 Autobiography V8
Post #520593 4th Jul 2019 6:35am
gt40
I did the removal myself and did not drop the subframe. I followed the manual to the letter which made it more time consuming. In retrospect I should have tried to find ways around the laborious Land Rover process. There are always shortcuts if you engage brain and look for them.
Ideally you need to have your forearm extended 30cm with a second elbow fitted and your hand reduced in size to that of a 5 year old. Then it will be a piece of cake. Smile
Post #520594 4th Jul 2019 6:50am
Roger3
Described me to a tee, and I'll look forward to the cake after.
I'll let you now how I get on. 2008 L322 TDV8 Vogue
Post #520595 4th Jul 2019 6:55am
Diditg
Turbos
Could you let me know who did the job, I’m not far away and have a similar problem.
Post #606402 14th Sep 2021 10:58am
Page 2 of 3 <123>
