Home > Maintenance & Mods (L322) > Rear Propshaft Centre Bearing
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
It seems my centre bearing is failing, Ive had a very light metalic rattle / rumble for a little while. Now I have a distinct rumble between 30 and 50 mph, just been under the car and the centre bearing rubber has perished.
Have any of you guys replace the bearing only or done the whole shaft?
AJG BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #520491 3rd Jul 2019 2:28pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Did one on a RR sport which would be a very similar job, exhaust off then remove the heat shields. I just changed the whole unit as didn't fancy starting to split it. Better with two people as the exhaust and prop-shaft are heavy. Good luck Thumbs Up
Post #520515 3rd Jul 2019 4:11pm
AJGalaxy2012
Thanks DD, I have decided to chicken out and let Green Oval do it, a lot easier from a ramp, they say 1.5 hrs which is fine. BMW i3 Electric Car
Post #520520 3rd Jul 2019 4:37pm
AJGalaxy2012
Well Ive just got back from Green Oval. I turned up at 13:30 (30 minutes early), the car was straight on the ramp. At 14:30 I was on my way home job done. New GKN propshaft fitted, theyd had several issues when replacing the bearing only. Car now vibration and horrible noise free!
Thank you Green Oval, once again you came up with the goods, great service, great company, absolute respect.
Post #520763 5th Jul 2019 5:41pm
