Home > In Car Electronics (L322) > TFT SCreen fault
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
TFT SCreen fault
Gents. my clock on my TFT is flashing on and off intermittently...known fault?
cheers
Chris
MY12 TDV8) 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #481026 16th Jun 2018 1:22am
havnt heard of this before..have you tried re-setting the clock to a different time and then back to the proper time..
or failing that ,do a battery disconnection.. ... - .- -.
Post #481040 16th Jun 2018 8:29am
Baltic Blue
Does it get very hot in Brisbane?
The only two reported TFT problems have been caused by “overheating”.
It might just be worth checking that the fan is running OK.
I would have expected some form of air filter on it similar to in the seats, but I can’t see any mention of one, or the need to clean it ?
Post #481044 16th Jun 2018 8:51am
BlackPerth
Thanks guys, its actually not that hot here presently...well its a mild 22 degrees C!
I hear its a tad hotter in the Australian Cricket team dressing room....!! Rolling with laughter 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #481426 20th Jun 2018 10:28am
GGDR
Bit odd this evening - my 2011 dash TFT failed to come back on after I ran into a shop. I was 5 mins and - dead screen on return and startup. Nothing.
No flashing, no signs beforehand just dead.
Will check in the morning. And also check with the IID.
Could it be as simple as a fuse?
Also hoping just one of those weird gremlins that a sit overnight will sort.
Wishful thinking....
Any thoughts ?
. Cheers, Greg
Post #520404 2nd Jul 2019 8:08pm
GGDR
Glad to report this one is sorted;
Like Terminator, it fixed itself overnight.
. Cheers, Greg
Post #520470 3rd Jul 2019 11:50am
Baltic Blue
Good news Greg Thumbs Up
They certainly like to remind us whose boss Rolling with laughter
Post #520473 3rd Jul 2019 12:00pm
i've come across this before when the battery was starting to go flat..worth checking yours greg. ... - .- -.
Post #520476 3rd Jul 2019 12:07pm
