Home > Technical (L405) > Gearbox fault |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Lots had this issue and it was a replacement rotary switch pack unfortunately... If you don't have a warranty then approach JLR, they may help as its a known issue |
30th Jun 2019 11:56pm |
ruzman Member Since: 31 Oct 2018 Location: Surrey Posts: 6 |
Thanks, do you have any more information on the rotary pack fix (sorry I couldn't find anything searching the terms)? BTW the car is 2014 3.0SE. |
1st Jul 2019 5:55am |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 |
I got the Gearbox Fault on my P400e. It was freezing conditions and I had been running the remote heat for 30 mins, had previously done some short journeys the previous day, and so the battery voltage had dropped very low. The engine would start normally but Drive could not be selected. I ran the engine for a while, turned it off, locked it, waited a few mins and then restarted to find all was fine.
16th Dec 2022 7:59pm |
