Home > Technical (L322) > Egr thermostat leaking
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
So I've sprung a leak on my td6. Was easy enough to find the source. It's coming out of the join between the plastic egr thermostat and metal egr cooler (at least that's what I think they are). Guessing there's an o-ring or something in there? Resisted the temptation to just nip the bolts a bit 😀 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #520027 29th Jun 2019 2:02pm
SidewaysMatt
So I could get a complete unit from euros in the morning - listed as BMW but looks the fella:
https://www.eurocarparts.com/search/209110431
Any good? 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #520029 29th Jun 2019 2:08pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
It looks good to me buddy 👍
Jim
Post #520032 29th Jun 2019 3:09pm
How to change the egr thermostat without removing the viscous fan etc. Thumbs Up
https://www.fullfatrr.com/forum/post500212.html#500212
Post #520069 29th Jun 2019 8:39pm
SidewaysMatt
Thank you sir 👍 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #520110 30th Jun 2019 9:13am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
What are the symptoms of this leak mate? Rough idle etc.... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #520221 1st Jul 2019 11:13am
SidewaysMatt
"Check coolant level" displayed on the dash, and a little puddle of coolant on the driveway Laughing
I took the front engine cover off (above the fan) and could see the coolant weeping out of the join.
Got a new EGR thermostat from Eurocarparts (£28 in one of their "sales"), will be fitting it tonight. 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #520223 1st Jul 2019 11:49am
MarshallW11
Canada 2003 Range Rover Vogue Td6 Giverny Green
If you run into any troubles with that you could also just remove the whole EGR and EGR cooler assembly! Clears up a ton of space in the engine bay and simplifies things.
Post #520329 2nd Jul 2019 11:42am
