Home > Technical (L322) > Over-excited fuel gauge
topgeartowers
Hey lads,
My Westie has started getting over excited with the fuel gauge. A few days ago it was creeping down to 54miles to empty, then whilst in solid traffic shot up to 121miles to empty. Then slowly ticked down to 70 over the next 15mins.
Then today it was 94miles to empty, then bounced to 161miles to empty - again whilst in heavy traffic (so it's not like I've moved to motorway or something that might mean the trip could recalculate).
Car has LR warranty, but it takes weeks to get it in, and I don't want to send it there with no idea of what the problem might be.
Any ideas?
Thanks!
Post #519930 28th Jun 2019 12:36pm
DrRob
Call LR Assist Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #519931 28th Jun 2019 12:40pm
topgeartowers
As a way of getting the car in quicker? Or because you think its about to totally conk out?
Post #519934 28th Jun 2019 12:54pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
What car is it?
There are known issues with certain models.......... Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #519936 28th Jun 2019 1:11pm
topgeartowers
2012 Westminster
Post #519941 28th Jun 2019 1:27pm
Bushy30
TDV8?
If so there are known problems with connectors in the fuel tank -- easy fix, cut them out and solder the wires together.
More problematic to get to though -- if they fail, the car will stop before it runs out of fuel, or at least think it's going to run out of fuel, there may actually be fuel in the tank of course.
There can be up to 4 connectors in the tank that need removing, mine 'only' had 3 !
http://www.fullfatrr.com/gallery/albums/us...8-6294.pdf Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #519942 28th Jun 2019 1:39pm
topgeartowers
Yes, 4.4 TDV8
That service bulletin is really, really helpful.
Do they tend to 'get worse' (more inaccurate fuel gauge) or am I just looking at a fail eventually?
Cheers
Post #519947 28th Jun 2019 1:57pm
Bushy30
Could fail anytime -- no warning -- my advice is get it fixed, quite quickly, don't get stranded somewhere because the car thinks you are out of fuel Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #519950 28th Jun 2019 2:06pm
Baltic Blue
Stan,
Please can this Technical Bulletin be added into the Wiki.
It is only a matter of time before all us 2010- 12 owners need it. Bow down
Post #519959 28th Jun 2019 3:10pm
Bushy30
If it helps -- I know how to fix the plastic bits that are likely to break too! Whistle Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #519960 28th Jun 2019 3:13pm
topgeartowers
Thanks so much for the quick advice!
Post #519963 28th Jun 2019 3:52pm
