![]() | Home > Technical (L322) > water shedder |
slim_sane Member Since: 09 Jan 2011 Location: Kent Posts: 43 ![]() ![]() ![]() |
Looks like I'll add it to my to-do list, I've got loads to do tomorrow might get round to it in a few weeks when I have a free weekend! Not had any water ingress in my at all but better safe then sorry as my car sometimes doesnt get used much I wouldn't notice if it did suddenly happen! |
![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Well , unless the one I have has some clever anti-shrink and set the car on fire properties it may as well be a bin bag |
hi i have just got my new one and it nothing like the one we fitted to my mates car, this is preformed and looks like the cover your mum would put over the arm on the best chair... V8 facelift Range Rover Autobiography 22" wheels.
Sounds exactly like what I've got! |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Wouldn't a 5litre Ice cream container or a large Tupperware box cut to fit be cheaper than the LR bin liner? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Fitted mine today. Three bolts out on my '03 Sat nav bracket off.. Then installed the bin ba... er water shedder... fed one antenna cable through with a small hole.. then three bolt holes. The product does make perfect sense when installed and will protect all the electronic gubbins. It also clearly made of a material designed to withstand the heat the various devices create.
did you take any photos V8 facelift Range Rover Autobiography 22" wheels.
What I don't understand is why LR wouldn't just fix the problem? Not all RR's leak, so there must be an issue with the ones that do?
Richardmellis Member Since: 06 Sep 2011 Location: Edinburgh Posts: 2 ![]() ![]() |
Has anyone got any idea how to fit the water shedder EOT500030 as it doesn't come with instructions and the one sheet I've managed to print off bears no relation to the 'armchair' cover I have. I've already replaced an amp and a radio because of water damage so I'm keen to fit this correctly and avoid another expensive replacement. And if anyone has worked out where the water comes in and knows how to stop it on a 2002 vogue l322 that would be terrific. All help gratefully received. Cheers richar |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35527 ![]() ![]() |
its in this thread i think..btw welcome to the forum richard .
Is this not a design fault? If so should'nt these shredders be supplied for free? Present :2008 TDV8 HSE
yes and yes.. |
