![]() | Home > Technical (L322) > 4.2 supercharged coolant hoses p/n under the supercharger |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Mine has just had the hose replaced and the hose alone was £262.82. The labour was significant and looking at the pile of parts on the workshop floor, I'm not surprised.
Diesel des Member Since: 26 Jun 2019 Location: Northern Ireland Posts: 16 ![]() ![]() ![]() |
V8noise, thanks for the response. Does the hose just connect to two things, or does it have multiple offtakes? You don't happen to have the old one that you could grab a picture off? I want to be sure I order the correct one. Did you get yours from the dealership? Cheers des |
All done by my indy Des and I'm out of the country so haven't even seen it yet.
That's no problem. I will do some more digging. Anyone know of a resource that has diagrams and part numbers for these machines? I'm used to vw Audi cars and there are some great resource for those, effectively what the dealership uses so you can find exactly what you need. |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
You can check the wiki as there's three parts catalogs (third party 'clones' of the original) for free.
Can anyone pick the hose required out from this diagram? |
Hopefully attached now. |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
if you still need a pic of were hoses go from and too tehn i can take a few snaps from under the blower as mine is currently in pieces?? If In Doubt Give It A Clout
That would be ideal thanks! |
Thanks for the help guys. I have ordered this which I think includes the 2 hoses you described. https://rover.ebay.com/rover/0/0/0?mpre=ht...3113089606
Just to confirm the hoses I linked fitted fine. |
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 70 ![]() ![]() ![]() |
I am having the same done by powerhouse. Could I ask did you ever have the part numbers for the hoses please? Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
