Home > In Car Electronics (L322) > Venture cam - caddy. Not charging |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 53 |
i had the same problem when i rebuilt cam
29th Jun 2019 2:00pm |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
Hi Jordon,
1st Jul 2019 10:04am |
i used an old cordless drill charger with wires connected
1st Jul 2019 5:25pm |
That's quite a good idea. I suppose it's pretty straight forward to put a multi meter on the charge points and if the meter shows a + voltage then the wires are the right way around, and if it shows a negative voltage they are the wrong way. I'll have a go with a drill charger myself and see. Thanks for the help. |
2nd Jul 2019 7:48am |
Currently charging, I chose the 400 ma output charger rather than the KABOOM 4amp one Will re connect all wires and hope for a fixed venture cam.
2nd Jul 2019 8:50am |
Thanks Jordon, your tip did the trick. I got some charge in it and now it is working again with the car.
2nd Jul 2019 9:59am |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 |
Hi sorry to resurrect a old thread! I have the same problem how exactly did you charge the VC with a hand drill charger ?
15th Oct 2020 6:35am |
Hi Ian,
15th Oct 2020 7:48am |
I see so you had opened up the venture cam and gone directly to the battery pack |
15th Oct 2020 9:00am |
Hi Ian,
15th Oct 2020 1:06pm |
