Home > Technical (L322) > 2008 L322 suspension fault |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
The suspension fault codes really need to be read before doing anything to avoid unnecessary expense investigating and replacing components. |
24th Jun 2019 8:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
But worth trying NOT lowering it, and see what happens. This may help with diagnosis. .
24th Jun 2019 8:58pm |
superted2008 Member Since: 26 Feb 2019 Location: Liverpool Posts: 11 |
I will stop lowering it and see how i get on.
25th Jun 2019 4:22pm |
I stopped lowering for a couple of days and still got the fault.
28th Jun 2019 12:13pm |
You should check for any leaks, but more likely the compressor has had it, you will have to do a time vs money assessment. You should be able to find a "barebones" compressor, which will save some money, if you are comfortable with a bit of dismantling and simple wiring. I could be wrong.... .
28th Jun 2019 12:52pm |
Macca Member Since: 04 Oct 2016 Location: Nottinghamshire Posts: 21 |
sounds like the compressor. D3 TDV6 SE 2006
30th Jun 2019 7:11am |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 151 |
I had a similar issue last year. A red dot over one of the wheels and slow compression. Then total suspension collapse where car was driving on its wheels. Called my specialist who said height sensor. Less than £200 later problem solved with replaced height sensor. Current:
2nd Jul 2019 2:24am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Put the car into off road mode, if the car achieves that mode and you don't hear a big hissing sound (as you open the hole that's leaking, usually covered by the bag being partially rolled over) then look at the wiring to all the height sensors (clearly visible through the wheel arch on off road height) Don't be afraid to give each wire a little pull!!! I often find broken wires that are only held together by the sheathing, but the wire inside had fatigued and snapped! |
2nd Jul 2019 8:38am |
I have looked a little further into this and I have come to a possible conclusion as suggested that the compressor is at fault. Shame really as it was only bought in 2017.
5th Jul 2019 2:55pm |
