Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3780 |
Good evening gents,
20th Jun 2019 9:29pm |
Matt,
20th Jun 2019 9:44pm |
That is the recommended way to check for any air leaks on the inlets, but ?.
20th Jun 2019 9:52pm |
Matt,
21st Jun 2019 8:26am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4309 |
Which Indy? AL Services? Bournemouth LR? Douglass ? Evans Garage? R&E?
22nd Jun 2019 7:06am |
Fair enough Matt, you seem to be getting good service from the dealer and hope we all learn from your experience.
22nd Jun 2019 7:11am |
Be good to see what their diagnosis will be. Greg mentioned potential throttle body issue - did LR Christchurch say that was an area to investigate?
22nd Jun 2019 3:09pm |
Cracks in the Plenum chamber are common because the weld on the seam has failed, but again ,this would have shown up on the smoke test.
22nd Jun 2019 4:48pm |
Matt,
23rd Jun 2019 7:00pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Thought I'd show a regen happening at low speed / low revs:
23rd Jun 2019 7:20pm |
As I understand, it measures exhaust pipe pressure before and after the DPF and from this calculates flow rate.
Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
23rd Jun 2019 7:32pm |
Matt, not wanting to get involved but certainly curious
23rd Jun 2019 7:35pm |
Fair enough!
23rd Jun 2019 8:44pm |
Component description of the differential sensor from the WM:
23rd Jun 2019 8:47pm |
