![]() | Home > General (L405) > New owner with a few issues. |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 788 ![]() ![]() ![]() |
1. I bought 10L of branded Ad Blue from Morrison’s last week for £8, so no need to buy the LR stuff at exorbitant prices. Probably not worth rejecting the RR for this item. As for the pads, I would negotiate a deal with the original dealer to have them replaced locally. Again, not worth rejecting the RR if it’s a ‘good un’.
Statler Member Since: 22 Jun 2019 Location: Leeds Posts: 29 ![]() ![]() ![]() |
hi Phil,
specman Member Since: 20 May 2010 Location: Fife Posts: 250 ![]() ![]() ![]() |
I do know you will be left with holes in the rear bumper which will be visible.
Thanks will register shortly, just off to Morrisons.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
Yes, but only works below a certain temperature, so you won't be able to use / test at the moment IIRC |
Yes, the key fob is for the Aux Heater only. It not only warms the engine but the whole cabin for up to 30 mins (max) up to 15C, if recall correctly [subject to battery life allowing]. I normally use it for around 20mins. This is enough to clear a frozen windscreen and provide a toasty cabin on a freezing morning |
Bigfella70 Member Since: 22 Jan 2016 Location: Yorkshire Posts: 106 ![]() ![]() ![]() |
Hi there, in terms of the Ad Blue and brake pads the supplying dealer have failed to PDI the car correctly. This is unfortunately not an uncommon issues judging by some threads on here.
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 910 ![]() ![]() |
Keep the mudflaps, you'll regret it if you take them off!
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
Are you sure the pads are low? Last year a main dealer said that my pads were low and I only had 1000 miles left on them and that the discs were beyond their wear limit and needed replacing. It's just been MOT'd by my local independent garage and as I've done nearly 10,000 miles since the main dealer report I asked them to check the wear out on the pads and discs. When he dropped the car back he said the discs and pads were fine and not worth changing at the moment as he thought it would be a waste of money! Cheers Ian
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
sounds like your car got the classic "not worth the paper its written on" PDI. In other words, whoever did the tick sheet did so without looking at the car and amazingly... it got a clean bill of health.....This is happening more and more as dealerships try to eek out as much margin from each unit sold. Of course any jobs that a PDI uncovers means less profit on the car when sold. Their hope is that jobs either don't get noticed or go unchallenged by the customer.
They have been stalling for time, the sales manager has been away on holiday apparently. ive taken that at face value as I've been promised it will be resolved today. They have until 1pm and then i'll be pulling the trigger on the 30 day guarantee from Land Rover.
Hope all goes well whichever direction you end up going in.
Not at all, it was a dealer in the Midlands, it was in their group stock so purchased direct and popped down to get it.
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Part of the issue is likely to be that JLR probably view Adblue just like fuel and that if its not got much that's the drivers issue.
