Home > Maintenance & Mods (L322) > New car water ingress help
Danwilderspin
Hi all - noticed my bt wasn’t working and someone pointed out they get wet... it was.. and it was soaking. It has a polythenes sheet behind it which was peeling off and water dripping off the sheet onto the bt. Also the driver side rear seatbelt is saturated but not the headlining anywhere? Any ideas where to start looking for this? I have noticed the sunroof sat back down about 8mm so have now reset it (07 s/c)
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #518376 13th Jun 2019 8:10pm
Danwilderspin
Ok update on this the rear driver side of the boot the headlong is wet and dripping near the rear fuse box - any ideas? As a temp fix when the rain stops I was going to try duct taping the gps unit? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #518380 13th Jun 2019 8:48pm
rjff
Dan
ISTR that the sunroof drains may block and cause this. There's quite a bit about water ingress if you search, even down to JLR retrofitting the plastic sheet. I am not sure but there may be a ventilation in the rear sidewalls of the boot storage cubbies. On other cars these sometimes break up and allow water into the area. Cheers
Richard
Gap IIDBT
Post #518394 13th Jun 2019 9:16pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Also water gets in through the sat nav aerial on top of the car I had a leak here I ran a bead of silicone around the base of the sat nav aerial easy fix. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #518773 17th Jun 2019 4:00pm
Danwilderspin
Jaysta I have put duct tape on for now but will do your trick next
The aerial doesn’t work had to get a new one I got an internal one would this point to this being the problem if it got wet? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #518795 17th Jun 2019 6:21pm
Danwilderspin
Right update after today’s downpour
front is not leaking so fixing the sunroof may have helped this - the boot is dry as a bone in both cubby holes so I’ll silicone the gps but the driver rear seat headlining is soaked down to that seatbelt so I’m guessing I’m going to drop the headlining now I know it’s coming from there!? Any ideas what it could be here? Is there a common thing?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #518956 18th Jun 2019 9:17pm
Danwilderspin
Ok as its dry now I tried to clear all my sunroof drains 3 wer blocked! 2 driver one passenger. Passenger front and back are now flowing well driver rear also the same BUT. The driver a front one I've tried striker cable brake cable etc and I can't get more than 8 inches down I can't blow it clear its so built up and I can't get in underneath as the compressor cylinder is bang in the way... Any advise please ? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519039 19th Jun 2019 9:50pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Dan,
you might find this interesting (drain tube touching air cylinder solution) that I cured.
www.fullfatrr.com/forum/topic33664.html
Post #519048 19th Jun 2019 10:23pm
Danwilderspin
Morning got up early (in a rage about this) had a look it’s not touching and as I have deployable it looked like a massive ball ache before work - so had an idea rather using are to blow it clear (which I understand is a no no) I got the dyson out and fashioned a pipe to it with gaffa tape and I manage to suck enough crap out to then be able to blow it clear and out a couple of kettles of water down. Result! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519070 20th Jun 2019 9:21am
Danwilderspin
Hi all,
This is back again - not as bad but its definitely back.
So far I have >
cleared all drains and tested with a good flow.
Siliconed around the gps antenna.
today went out and pulled the rear driver seatbelt out and it was soaked after last nights down poor.
Also on the same side when I opened the boot a tidal wave of water ran down the right side of the boot.
It is parked n a slight angle so water would be on the right.
Is it normal for there to be a big rush of water like that? Where is the next place to check?
thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526453 29th Aug 2019 2:44pm
Danwilderspin
Hi all still need some with this after this weeks heavy rain I have a bit of an update - double checked drains all good - but there was a very wet spot about the middle of the rear passenger door - right on the edge by the door it was soaked... any ideas what is hear to cause it it was so wet it was brown.. also took the sub out to fix it and it was wet there it looks like runs down that pillar into there..? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #530138 5th Oct 2019 11:06pm
