![]() | Home > Technical (L322) > Misfire on 5.0 s/c |
Skeletor Member Since: 06 Apr 2019 Location: Cornwall Posts: 18 ![]() ![]() ![]() |
Got a bit of an issues with my 09 5.0 s/c, light acceleration at around 1400-2000 revs getting a misfire, hard acceleration or just nursing it past this rev range seems to be ok, had it plugged in and got
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
Did you changed the right side? From the WM.......
You could well be right I was going off this I had off another member:
Hope, if you switch the sensor, it wil work.
Also, check for a airleak in, somewere along the air intake.
Any luck on this Sir? |
Tried another new sensor in the other side and I think it’s sorted now. Difficult to tell 100% as it didn’t do it all the time |
Good job, hope it works and stays that way.
Took the car for a good drive over the weekend, still has same issue. Would ‘P0420 catalyst efficiency’ give this sort of misfire / hesitation? |
I dont know Sir, but Ill think best is to begin with any leaks in the inletsystem
