Home > Maintenance & Mods (L322) > Is this what a bad cat sounds like?
Danwilderspin
I have a cat fault come up so decided to hit it to here how it sounded? What do you guys think? Right at the end of the video it sound like bits are vibrating...
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #518572 15th Jun 2019 12:13pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
It does sound like the core is loose and may well rattle itself to death. If it's still working you may get some more life out of it by slightly denting the canister. I did this on a car a while ago and it carried on fine with no rattles for 3 more years. I put a g-Clamp on it in three places and crushed the out er can.
AJG BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #518597 15th Jun 2019 5:08pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Bit late on this ..
Have you had a good look underneath at the heat shield? Had a similar issue on mine and like you thought it was the cat. Turned out the heat shield had dropped down onto the cat. Rattled a lot on low revs and also when turning off the engine ..
Couldn't see the heat shield was touching until I got right underneath and looked/ felt along the top of the cat itself.
Cheers
Simon
Post #521153 9th Jul 2019 7:35am
