Home > Maintenance & Mods (L322) > Transmission filter + gasket
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Probably a silly question:
I've order from aboard one filter plus gasket kit for the GM gearbox. The supplier only send me the filter and make a great mess with the gasket. Now I only have the filter. Here no one sell only the gasket.
Can I use the old gasket with a little of RTV silicone to prevent leaks?
Post #518158 12th Jun 2019 10:35am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
If you are lucky the original gasket is made from alloy with a rubber lip. These come off easily with no damage and I would happily re-use if there was no option. If it helps the Gasket and filter from a BMW x5 with the same engine/gearbox is the exact same. There are 2 types of filter for this gearbox, one has the pickup from the bottom, the other from the edge. You want the one with the bottom pickup. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #518168 12th Jun 2019 11:25am
A.Pires
Hi Wayneg
Thank you very much for your reply.
I'll do that
Cheers
Post #518989 19th Jun 2019 9:41am
