Home > Technical (L322) > ABS Bleed Diagnostic Tool
Jacckk
2010 Range Rover Autobiography 5.0 SC V8 Mariana Black
Hi,
After having a brake line burst and the master cylinder drain on my 2003 RR my brakes have never felt quite right. I've bled them at least 5 times but it always feels soft. The car still stops fine it just feels soft.
It seems likely that the ABS modulator needs bleeding. I've seen posts on X5 (which have the same DSC 5.7 system) forums that said they needed to be bled with diagnostics to get a proper pedal feel.
Does anyone know of any diagnostic tools which can perform this procedure? I emailed GAP and they said that the iidtool can't perform this procedure. The faultmate from BBS can but is pretty expensive.
Thanks
Post #517909 9th Jun 2019 7:19pm
Have you tried running the HDC (find a nice long hill!) to get the ABS modulator "jiggling" - this is all the LR diagnostics do, as far as I know. You may need to bleed again afterwards. .
Post #517911 9th Jun 2019 7:33pm
