Home > Technical (L322) > Superlock problem 2004 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
If driver's door manual lock broken / not working, and remote functionality not working, no point in getting a new key from Land Rover I guess. As you say because the car is superlocked pulling on the door pulls wire wire will not work, neither will pressing the unlock button on the dash.
7th Jun 2019 4:02pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
I know you say the fob doesn’t lock / unlock and that may be a problem deeper within the car not the fob, soooooo have you tried holding down the unlock button to possibly roll down the windows.
7th Jun 2019 6:38pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Dear sirs, thanks for help. Now I have new idea: will take a hacksaw or an powercut and cut out the right part of the cylinder holder from the door handle (it is LHD), until I cut the little torx screw, which is from inside behind a rubber part. Then will take a screwtool and open the X ...., new door handle is ordered at breaker!
9th Jun 2019 11:56am |
