Update
Variable valve solenoid replaced , this cleared the Error code for the Solenoid, not a terribly hard job as it was the cam cover on the side that is not covered by all the AirCon Pipes.
Contacts cleaned on both Camshaft sensors
All error codes gone and runs sweet as a nut again.
On Obtaining the solenoid, LR Part was over £659 with the VAT, Jaguar was £152 and they are exactly the same part.
BUT the item is made by Gates Corp, which are an OEM for a lot of fluid power , hoses and belts believe it or not , so purchased via rockauto.com in the US for £43.09 ($53.79) and it arrived in 4 days !
I like a job that goes well, even better when it is a dam sight cheaper that expected, which lets face it is not very often with a FFRR
