Home > Maintenance & Mods (L322) > MY2010 Climate panel fit earlier?
Danwilderspin
Before anyone says this has been to death., i know but my question is a little different. Will the panel actually fit in the gap where the other two modules sit? its would be a MY07 - thinking of buying one and using the old units behind the scenes and just the fascia from the newer module... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517494 5th Jun 2019 10:02am
that panel is a single unit about an inch thick with sockets on the rear...i'm pretty sure its not plug and play though..
Post #517496 5th Jun 2019 10:16am
I looked into this a while back, as my heater panel lighting is very dim.
Like Stan, I reckoned it wasn't plug and play, as the connectors were different. Got - 2017 SDV8 Autobiography in Loire Blue
Post #517497 5th Jun 2019 10:20am
Danwilderspin
yes I get that but I was literally going to buy is and take the front off and mount the old modules behind if that makes sense - but wanted confirm they'd fit first...
cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517500 5th Jun 2019 11:35am
the 2010-2012 panel is one piece and all the knobs are integrated into it and does not have separate modules.
Post #517510 5th Jun 2019 2:25pm
Danwilderspin
yes got that Stan but I was literally going to take the black plastic off the front of it ant the buttons (not the module) do the same with the originals and then put the new buttons and black front on the old modules but before trying wanted to confirm the one piece would fit.. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517511 5th Jun 2019 2:34pm
not sure if it could be separated dan..
front,
rear,
Post #517513 5th Jun 2019 2:58pm
Danwilderspin
hmmm .. I might buy one to check it out Very Happy Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517515 5th Jun 2019 3:01pm
Baltic Blue
They are interesting pictures, Thanks Stan,
I haven’t delved into mine, but the clock is doing funny things...
It is right one minute, then next time I look it is stopped, then , it just fast forwards for no reason and is fine again.
Cheers
Post #517517 5th Jun 2019 3:06pm
loose connection mike??
Post #517519 5th Jun 2019 3:15pm
Baltic Blue
Time will tell Rolling with laughter
Post #517521 5th Jun 2019 3:20pm
Laughing
Post #517522 5th Jun 2019 3:25pm
Dan, even if it were possible to do as you wish... JLR moved the switches around in the 09> so that would nt work in your favour either sir...
Post #517575 6th Jun 2019 12:33am
cass
I’m curious, why do you want to do this?
Post #517577 6th Jun 2019 5:02am
Danwilderspin
Yes I spotted that but as the buttons looks the same size I thought I’d just swap them around.
Why would I want to do this? I prefer the black colour to the old fashioned grey - I’d also spray the screen so it would look a lot more modern up to date Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #517581 6th Jun 2019 6:51am
