Home > General > Transmission Fault ?
Andpopse
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi Guys,
I am experiancing a slight fault. What happens is at low revs/tickover, Drive does not always seem to engage straight away, the revs just rise and no forward motion. This happens especially when slow cornering. I have also noticed the D (on the display) is either flashing or not showing when this happens. The vehicle has not done high miles (20000), and there are no strange noises or any other indication as to why this occurs. It is intermittent although i am noticing it more.
It's a 4.2 S/C
Any Ideas ?
Thanks
Andy
Post #51734 24th Feb 2011 3:06pm
i'd check your transmission fluid you might have a leak ... ... - .- -.
Post #51740 24th Feb 2011 3:48pm
bozmandb9
Andy, this may sound strange, but I just wonder if it might be related to your battery. I have a 2006 MY S/C, I have gearbox issues, and I'm pretty sure mine are caused by a failing battery giving low voltage, causing faults. Mine is particularly bad at idle, low revs, which is why your description rang a bell.
First thing to check is the indicator glass on the top of the battery, mine is black, and remains that way even after driving all day. It will be replaced tomorrow.
Hope yours is something simple!
Just love the S/C though! Range Rover-less at the moment - Pining!
Post #51904 25th Feb 2011 8:25pm
Andpopse
I phoned my local LR dealer who suggested it may be lack of lubricant at the selector cable / gearbox area. So I've decided to get transmission fluid changed and selector checked and lubed. The battery starts the car with good power even after 2 weeks of no use, but I will get it checked --- thanks for the suggestion.
btw I am using an independent based in Bristol (Sreve Hill) if anyone knows of his reputation, it would be useful to know.
Thanks
Andy
Post #51910 25th Feb 2011 8:48pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Steve Hill is very experienced and thorough with LRs and has been a great help to me. He is expensive however. I would def ask him for a quote but also check out other Transmission specialists. Dan_1984_uk has had his transmission oil changed but I can't remember where (it was around Chippenham area). if you have the cash, Steve will do a very good job.
Post #51917 25th Feb 2011 10:14pm
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Re: Transmission Fault ?
Andpopse wrote:
Hi Guys,
It's a 4.2 S/C
Any Ideas ?
Thanks
Andy
Ive just posted EXACTLY the same problem!!? If you have nothing nice to say,say nothing at all.
Post #52080 27th Feb 2011 11:01pm
bozmandb9
Seems to be a common problem amongst S/C's all of a sudden!
Hope people will post when they find resolution! Range Rover-less at the moment - Pining!
Post #52092 28th Feb 2011 8:40am
RRV
Mines booked in for Wed morning....apparently a sofware update/TSB is needed.
Its not really that bad but I know its there and it bothers me now! Big Cry If you have nothing nice to say,say nothing at all.
Post #52111 28th Feb 2011 12:26pm
Andpopse
Further Findings............. When in Drive if pull the gearleaver backwards, D reappears and I have drive. I have also found Sport / Manual does not give any drive.
I am thinking this points towards a selector / cable issue.
Post #52153 28th Feb 2011 4:15pm
RRV
Hmmmm Confused If you have nothing nice to say,say nothing at all.
Post #52204 28th Feb 2011 7:13pm
RRV
No drive in Sport/Man whilst D has dissapeared or no drive at anytime? If you have nothing nice to say,say nothing at all.
Post #52205 28th Feb 2011 7:14pm
Andpopse
I didn't experiment enough, but could seem to get drive at all in sport/man.
Post #52233 28th Feb 2011 9:11pm
Andpopse
All fixed now and luckily not too expensive ! My gear selector and arm were seized, new arm fitted and set up, now it's silky smooth.
Post #52860 4th Mar 2011 10:22am
RRV
Mine just fixed itself!!
Just a "glitch"?? Thumbs Up If you have nothing nice to say,say nothing at all.
Post #52862 4th Mar 2011 10:27am
RRV
Who fixed it and how much for future reference? If you have nothing nice to say,say nothing at all.
Post #52863 4th Mar 2011 10:29am
