Home > Maintenance & Mods (L322) > Coolant leak |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
I would get the plenum chamber out and the engine cover off, and have a good look and wiggle of all the pipes at the rear of the engine, got to be somewhere there, the egr, oil and fuel cooler pipework is all in that area, behind the oil filter casing .
31st May 2019 1:20pm |
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 |
Cheers Joe. The plan is to tackle this tomorrow. Will keep you updated. |
1st Jun 2019 10:21pm |
Drip underneath was aircon. I can't for the life of me see where this leak is. everywhere looks dry. there's no creamy texture anywhere. I don't think it's getting in too the head gasket.
2nd Jun 2019 10:52am |
Must be coming out under pressure at temperature then, and more or less evaporates as it exits. I had this on my TD6 - it was a leaking seal on a bleed screw.
2nd Jun 2019 10:59am |
Any idea which or
2nd Jun 2019 11:15am |
Looks like I have located the leak. There's a very small break in the flexi pipe connected to the reservoir. I have some new clips to replace the rusted ones. I will cut the pipe as a temporary measure but are these pipes easy enough to buy? Will it have to be a Land Rover job to order from? Also, any ideas on a price. TIA
9th Jun 2019 7:31pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
I would also check your thermostat housing, if you shine a torch down around the oil filter if its leaking you will see the orange/red residue. It never actually drips anywhere as it just dries out. Common TDV8 issue.
9th Jun 2019 8:04pm |
Thank you for the reply. I will have a check tomorrow. I aim on replacing that broken hose anyway as that will be causing some problems, especially when the engine is hot. |
9th Jun 2019 9:09pm |
