Home > Technical (L322) > 2010 tdv8 torque converter question.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
Has anyone did a rebuild or repair on zf torque converters?
My mechanic tried and after 20k km it vibrates again.
Is it true zf torques are hard to rebuild??
2010 tdv8 150k km. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #516187 22nd May 2019 2:15pm
Mikey
We only fit brand new ZF/Sachs torque converters
Reconditioned parts are usually done to a minimum price, not a minimum standard...
Post #516205 22nd May 2019 5:37pm
umitbat
Some reconditioned parts are as good as new with much less price.
I am asking if this can be done with this part not if i should buy new part;) 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #516309 23rd May 2019 11:40am
Mikey
Yes, it can be
Post #516326 23rd May 2019 2:24pm
RRPhil
I’m not sure about the 8HP converter, but with the 5HP & 6HP units the difficulty is that the lock-up clutch is ‘captive’ i.e. the LUC piston return spring retainer is friction welded in position to the centre tower, very accurately, during manufacture. When the converter is re-manufactured the weld has to be removed, the friction plate(s) replaced and then the retainer has to be re-welded back into position again, very accurately. This is quite an involved process (https://www.youtube.com/watch?v=sslp8SqU-0Y) and should only be entrusted to a company with a lot of experience working on this type of unit. There are a number of ‘ZF approved’ places here in the UK with this capability e.g. JPAT, Sussex Auto Parts, Mackie Transmissions, etc. The need for accuracy stems from the fact that the LUC piston stroke is tiny (only around 1mm for the 5HP24).
Phil
Post #516375 23rd May 2019 10:27pm
RJDS
Phil,
When my gearbox gives up the ghost.... I’ll be bringing it to yourself. Not only are you clearly the fountain of all knowledge when it comes to ZF and GM gearboxes, your responses to questions posed by forum members is always insightful and never less than impartial.
Have a good bank holiday weekend. 🍻 2010 TDV8 3.6 Galway Green
Post #516439 24th May 2019 5:32pm
umitbat
RRPhil wrote:
I’m not sure about the 8HP converter, but with the 5HP & 6HP units the difficulty is that the lock-up clutch is ‘captive’ i.e. the LUC piston return spring retainer is friction welded in position to the centre tower, very accurately, during manufacture.,.............
Phil
Thanks one more time!!! 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #516442 24th May 2019 6:14pm
umitbat
Update...
Oil and filter change cured vibration for now Wink 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #528917 24th Sep 2019 7:31am
