Home > In Car Electronics (L322) > Bm54 amp outputs / amp inputs
Danwilderspin
Hi all - quick question I have the non dsp amp (the small square black job in the boot still) anyway with the stock setup the system sounded half decent and went pretty loud. I’ve now gutted the setup and put an android headunit in. Correctly or incorrectly I assumed the outputs from the bm54 unit would have been line level so I have wired the line level outputs to the amp inputs problem is it’s pretty quiet at full volume and very distorted then too - so the question is does the bm54 output line level but maybe at a higher volume or have I been a moron and should I have used the speaker level outputs to the amp (semi quick rewrite) any advice will be greatly received.
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #516092 21st May 2019 5:03pm
mjdronfield
The DSP isn’t an amp, it’s only a sound processor with crossovers inside etc to feed the speakers directly. I do seem to remember that the BM54 amp can do various functions but I’m no expert.
The biggest issue you will have is to get the BM54 amp to actually power on, because it uses a pulse on the ibus that comes from the head unit, that you have removed.
Technically, if you remove the DSP and amp, you won’t have any crossovers left in the system to split the correct frequencies to each speaker.
Though, I’m not sure if the BM54 switches to a different mode if it doesn’t see the DSP identify itself on the ibus.
I thought the DSP was standard on the Vogue?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #516094 21st May 2019 5:29pm
Danwilderspin
Cheers for the quick response - it’s the non dsp amp I have so it’s not ibus dependant so that’s not an issue. Do you think that this would be the same as the dsp though just an active crossover as opposed to an amplifier? Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #516095 21st May 2019 5:39pm
mjdronfield
I recon you will still need an ibus signal to get it to power on. I might be wrong, but I don’t think I am.....if you get me....
Might be easier to run speaker wires from your head unit into the boot, and pick the car speaker wires up from there? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #516110 21st May 2019 7:23pm
Danwilderspin
I know you don’t need ibus as that’s what I am have been running for a while with a different setup and it’s working ok now just quiet so think a repin to high level outputs to inputs is my next plan! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #516473 25th May 2019 8:09am
mjdronfield
You prob know more about that bit than me then. I’m sure I read it can switch between modes depending if DSP is there, but can’t remember.
Sounds like a plan.
Baris on here should be able to advise as he repairs and upgrades them.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #516478 25th May 2019 8:30am
