![]() | Home > Maintenance & Mods (L322) > Is my suspension Correct ? |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I have had Classis, P38`s and a L322 all with air suspension, they all do the leveling dance so enjoy the performance 2007 TDV8 VSE
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
The see saw dance of front to back is totally normal when raising , with mine the front goes first , followed by the back, has done it since new, when lowering it is more or less all four corners go down at the same time . |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1451 ![]() ![]() |
It's normal. I believe it's designed that way to put less strain on the air compressor and not deplete the air tank too quickly. 2021 D350 Fifty Edition - Carpathian Grey
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 ![]() ![]() |
It's designed to raise the rear first, to stop headlamps (when lit) dazzling on coming traffic. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
@ Cavalier
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
Mine comes up rear first |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Rear first here also - the idea is the front lamps don't dazzle when rising (as mentioned by Cavalier). |
