Home > Technical (L322) > Battery Disconnect/Towbar Electrics.
Brian Considine
2003 Vogue with BMW Infotainment system.
I'm about to install the towbar electrics using a Westfalia 2 x 7-pin dedicated kit which is "plug & play".
I've read conflicting information about disconnecting the battery negative terminal & iut seems that I should ;
1) Turn off the ignition, wait for 5 minutes & then remove the key. (keep it on me, not in the car).
2) Wait another 5 minutes & then disconnect the battery negative terminal.
3) Plug in towbar electrics.
4) Reconnect battery negative terminal & wait 5 minutes.
5) Key in ignition & start,
Have I missed anything ?
TIA, Brian 2003 Range Rover Vogue TD6
Post #515277 14th May 2019 8:16am
Brian Considine
Sorted - followed the above & apart from a couple of warnings which cleared after a short drive all seems to be in order.
Next job - pick up feed in overhead consule for dashcam. 2003 Range Rover Vogue TD6
Post #515306 14th May 2019 2:07pm
I've no real knowledge of this stuff Brian, but for reassurance its always worth checking in the Wiki (in the picture space at the top of the page). eg https://www.fullfatrr.com/forum/post67804.html#67804 Mike - MPx
Post #515324 14th May 2019 4:56pm
Brian Considine
Thanks for the info' - I did find that via Google but I just wanted to double check as the towbar electrics instructions just said to "disconnect the battery" with no reference to allowing systems to shut down.
All working except that the dedicated electrics do not like the LED indicator lights on the trailer (flashing too fast & a warning on the dash) - I'll sort that out with a couple of load resistors. 2003 Range Rover Vogue TD6
Post #515352 14th May 2019 8:41pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Load resistors will stop the fast flashing but won't stop the lights flashing as the ECU fires out its 2v bulb test pulse. You might not want your brake lights flashing randomly. I believe there is an aftermarket interface to cure this, you can stop it with relays. The testing might be stopped with diagnostics. I put it down as too hard and change the lamps to old school. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #515372 15th May 2019 6:52am
Brian Considine
I very much doubt if the LED's will react at all to 2v - IIRC the units are rated at 9 > 36volts.
The whole reason to change the trailer to LEDs was to save time replacing bulbs as they were forever failing due to vibration.
Interesting point though - thanks. 2003 Range Rover Vogue TD6
Post #515385 15th May 2019 8:56am
wayneg
The issue is the led`s will light up with a small voltage where the normal bulbs won't. The test system fires out 2v which will illuminate the bulb being tested and cause a flash. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #515387 15th May 2019 9:09am
