Home > Technical (L322) > Suspension inactive
Saxon
England 2003 Range Rover Vogue 4.4 V8 Java Black
Suspension inactive
Hi I've had my l322 just over a year and alls been fine until a couple of weeks ago when I got a message on the dash with suspension inactive when I took it to the garage to have the faults read it came up with abs canbus error and was told I needed a new abs module so in the week waiting for my second hand module to come I drove the car as all seemed ok. So I had the module fitted and it's made it 10 times worse the suspension wont move anymore all the lights on the dash are on the garage has told me it needs coding in and the havnt got the software to do it so I spoke to a local 4x4 centre and they said it cannot be coded in so I'm stuck really can anyone advise if it can be coded have you had same problems and what did you do cheers for any advice
Post #515097 12th May 2019 5:36pm
Welcome to the forum!
You won't want to hear this but it probably wasn't the ABS module, possibly the cable connector for the ABS, or a fault triggered by the Air Suspension... I could be wrong.
Search the forum for ABS, plenty on here, pretty sure a replacement can be fitted with the right diagnostic kit .
Post #515102 12th May 2019 6:01pm
yelnats69
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
Did you solve the problems
Post #540374 12th Jan 2020 11:13pm
yelnats69
Post #540375 12th Jan 2020 11:14pm
