![]() | Home > Maintenance & Mods (L322) > FFRR TD6 '02 Second Battery Fit Out |
rejo Member Since: 10 Feb 2013 Location: Netherlands Posts: 28 ![]() |
Fantastic installation. Well done👍👍👍 |
From SteveMfr's ebay link: . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Sorry to hijack this thread but I also have a 2nd battery in my tdv8 via a voltage sensing relay that allows some neat stuff (it doesn't just split when the alternator isn't charging thus allowing the faster charging optima to continue charging the starter battery when its stopped running and allows you to draw some current from the starter battery but should leave enough to start the car still as it will disconnect them before the voltage drops too low).
My thinking for future working is to do this:
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
After yet another fiasco of not being able to start the RR after only 3 days of inactivity. I have got all the bits together to do a second battery fit out.
9 months on thought I would report back.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
Joe,
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Just reading through this thread and would like to add my 2c worth. A few comments suggest using an isolator. I would say for safety please fit a circuit breaker which also acts as an isolator. It is a must when fitting a second battery, even more important if you don't have an isolating relay. I have attached a photo of my fitment, the 100amp circuit breaker on top of the battery can be opened and closed manually and is easy to access. The connection to the car is via a 140amp voltage sensing relay ( Hidden away) The connection to the car can also be easily broken via Anderson Plugs as I connect solar panels via the same when camping. The cigar lighter in the rear area has been disconnected from the car wiring and connected direct to the 2nd battery circuit breaker so I can run a fridge or other accessory's from it without concern it will be drawing power from the start battery at any time
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1543 ![]() ![]() |
Wayne, are you using one of Drivesafe's dual battery kits?
Ron, I Just got the bits from ebay, The charge controller is a Narva 140amp and was A$40, http://www.ebay.com.au/itm/NARVA-61092BL-V...xyPiJRi4WK Its fits sort of behind and under the rear O/S lamp nice and tidy and out of harms way. The 100a circuit breaker A$10...http://www.ebay.com.au/itm/12V-24V-DC-Home...GRG4kwR4BQ. I had the wire and Anderson plugs.
Thanks Wayne. I had thought of using a VSR. I have one of those circuit breakers somewhere. I bought it from Jaycar Electronics some years back. See http://www.jaycar.com.au/Passive-Component...r/p/SF2266 - a lot dearer there than A$10! Ron B. VK2OTC
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
I used the rear bumper bar bolts. VERY close, LARGE (M14? M17?), long enough to easy add a cable lug and a nylock nut to. bye. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia |
winaje Member Since: 05 May 2019 Location: Nth GA Posts: 3 ![]() ![]() ![]() |
Hi guys, is there a spot the same for the second battery in a 2012 SC? |
aterkut Member Since: 27 Nov 2020 Location: Eskisehir Posts: 11 ![]() ![]() ![]() |
hi;
