![]() | Home > Technical (L322) > Rear door Rubber window trim / finisher |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
It does look as though it could go forward a little. They are quite a tight fit length way. They just pull up & can be pushed back down, so you could have a go at realigning it.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Anyone got the part number for these ? Regards
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
Interesting. So with plastic trim tool, they will just pry upwards and off ?
Yeah just played with mine. Although now I want to replace it. So any part numbers would be great??
Daz, You need to check Microcat for the part No's as mine was 2006 & the part Nos were superceeded.
What’s microcat buddy? Regards
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
try CGE500720 Current: 2011 FFRR Vogue SE 4.4 TDV8
Microcat is the online parts catalogue.
