Home > Technical (L322) > 2012 S/C NS "Angel Eye" not illuminating |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 |
Ok, so I took the headlight out today and inspected it through the back caps for possible hints of why the LED rings wouldn't work. A quick test with a probe revealed that the headlight plug does indeed supply the current to the parking lights so it must be the headlight assembly that has failed to work. Obviously, there's so much stuff inside them it is not possible to have a thorough inspection on the guts without taking the whole headlight apart. Which I believe is only possible by heating around the plexi glass and cutting the glue used to bond it all together. So of course I didn't do that.
1st May 2019 1:25pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
the 2012 didnt have factory fitted halo rings in the headlights....it does have 'fairy' lights as standard though... |
1st May 2019 1:50pm |
Is that’s what they are called? I’ve no idea. Either way mine are unmodified, factory lights. |
1st May 2019 3:20pm |
