Home > Technical (L322) > Hill descent control
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hi, can someone explain HOW this works, does it utilise brakes or something else?
When I switch mine on it holds the car on an incline allowing slow travel.. BUT it makes groaning noises like something binding??
Do they all do this or have I a problem? Thanks. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #513382 27th Apr 2019 4:05pm
rjff
I think the noise you have is the system using the brakes etc. to control the car's rate of progress. It appears to pulse the brakes quickly (or not quickly), seeming like it's not at all well.
I've tried mine on a snowy/icy road decent and that's what it sounded like. Left it do it's own thing and the wife was rather apprehensive. Me, of course not Smile. No doubt someone will be along shortly to put us right. Cheers
Richard
Gap IIDBT
Post #513383 27th Apr 2019 4:10pm
DrRob
Sound is normal. Brakes doing their job Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #513389 27th Apr 2019 5:13pm
Rapiscan
Mmm? I wasn't sure if it was using brakes or a kind of telmar system as used on some buses/trucks where electromagnets are energised on the propshafts to create a "drag" to reduce speed.. OK as long as the sound we hear is the norm then, fine, thanks. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #513390 27th Apr 2019 5:23pm
rjff
We've got enough electrickery on ours without the prop brake system. Hope no one from JLR reads this or we will have more things they can engineer to go Censored up Rolling Eyes Cheers
Richard
Gap IIDBT
Post #513393 27th Apr 2019 5:33pm
Witzend
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Mine used to make an awful grinding sound when HDC was selected just as you describe, However, the target descent speed can be adjusted using the cruise control + or - buttons on the steering wheel. I adjusted mine relative to the gradient while HDC was in operation and was able to greatly reduce the grinding and banging noises.
Hope this helps.
Post #513397 27th Apr 2019 5:53pm
Rapiscan
Well ya learn something new everyday! I'll give it a go, ta! Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #513400 27th Apr 2019 6:45pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Use mine when descending out of a multi-story car park in Warrington. Reassured with all the creaking and juddering, as know that the system is working correctly! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #513443 28th Apr 2019 8:41am
kooky_guy
I have to say that mine is silent in operation! I'm sure its working though. 2010 4.4 TDV8 Vogue SE
Post #513630 30th Apr 2019 8:04am
Rapiscan
If its merely using the brakes, how is that better than me using the brake pedal? Rolling Eyes 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #513645 30th Apr 2019 10:08am
rjff
It will be calculating the variation between each wheel speed against perhaps the measured acceleration of the car and applying differing retardation to each wheel via the brakes. (I think) It will be likely more complicated than that but you get the idea. Cheers
Richard
Gap IIDBT
Post #513721 30th Apr 2019 4:20pm
mjdronfield
You can’t brake each individual wheel at varying levels to keep the car straight, using information from the sensors around the body.
I might be making an assumption there of course, you could have become fully assimilated..... Borg style.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #513726 30th Apr 2019 4:46pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
HDC is really for decent of slippery/difficult terrain decent where just using the brake pedal would result in a side slip, the HDC as above has been said uses each wheel retardation individually to balance the braking effort keeping the vehicle in a controlled decent, basically it’s not really for your multi story car park Laughing David
Please let me know if my comments upset you, I may wish to upset you again.
Post #513746 30th Apr 2019 6:51pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
get yourself on a 1:4 snow/mud covered hill and you will see the benefits, bloody noisy but does a great job Thumbs Up
Post #513748 30th Apr 2019 7:12pm
rjff
MJ
Me assimilated, I'm more likely to be exterminted by those pesky beasts with toilet plunger arms Confused . And anyway, the steering is always done by the most dangerous nut on the car, the one holding the steering wheel Sniggering
Rapiscan,
This is probably the only time we're happy the the FF making an unusual noise. As Rosco says, get to a hill, with lots of no grip and go Thumbs Up Cheers
Richard
Gap IIDBT
Post #513758 30th Apr 2019 8:07pm
