Home > In Car Electronics (L322) > USB in cubby hole
Andy
USB in cubby hole
What kind of power does the USB port draw?
I’ve just fitted an Amazon Echo Input in the cubby hole and connected via my 4G signal. I noticed it’s still on when I locked the car so I unplugged it just in case.
If I left it plugged in, would it flatten the car battery? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #513327 26th Apr 2019 10:29pm
DrRob
How long did you leave it locked before you checked it through the window? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #513329 26th Apr 2019 10:43pm
Andy
Not long. About 10 minutes 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #513330 26th Apr 2019 10:54pm
leave it a bit longer... Arrow
Post #513348 27th Apr 2019 8:12am
Andy
I assume then that it’s not a permanent live so I can leave it plugged in. That’s great. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #513349 27th Apr 2019 8:16am
its not normally a permanent live but someone might have messed with it to make it one....
leave for 20 minutes or so and check..
Post #513361 27th Apr 2019 10:09am
