Home > In Car Electronics (L322) > RSE screen connection
Danwilderspin
Hi All - do the screens for the use 05-09 just have a single video feed a live and a ground for them so I could lily repurpose them or do they have a lot more than this so need the rse module in order to work at all?
cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #513289 26th Apr 2019 2:11pm
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi Dan,
It looks like they have quite a variety of power supply needs for (what looks like) the backlight and a general power supply too - and there is a composite video in, but there are four 'IS-BUS' inputs (or outputs) at the bottom of this screen-grab that may be the spanners-in-the-works of getting the screens to be generally useful.
I hope this helps (a bit)
Let us know how you get on.
W
 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #513301 26th Apr 2019 3:38pm
Danwilderspin
hmmm.... Censored !
maybe if I explain.. I want to change the headunit but don't want to lose the RSE... if I do change it will the RSE be a no go or will it be ale to play dads/ aux in ok? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #513302 26th Apr 2019 3:49pm
Wrecker79
Ahh! Sorry, I misread your original question.
It looks like the Rear Seat Entertainment gets its feed from the head unit via the MOST Bus and a video feed from the head-unit that contains the TV signal.
So you _could_ (it looks like) remove the head-unit but continue to enjoy the rear seat entertainment, but, there would be a huge issue - when I had my L322 with the RSE package, the only way of selecting inputs was from the main touchscreen - there was a way from the rear centre console remote, but I do not know if this would render the RSE inoperative without the head unit at least initialising the MOST communication.
I guess the easiest way of find in out is to locate the Rear Seat Entertainment Module and unplug connector C2109...
2014 - L405 4.4
Post #513309 26th Apr 2019 4:51pm
