Home > In Car Electronics (L322) > radio dead l322 SC 2012
mohammed abood
United Arab Emirates
Dear reader,
Wish you a good day at first; I have a l322 2012 SC.I faced a small problem while using the car two days ago but I haven’t got any clues how to do it.
The radio just stopped working and the power button keeps blinking but everything in the radio features is dead no radio, nav, etc. it’s just dead.
I haven’t checked the fuses yet cause I don’t like to mess around. I like to do organized correct work.
If anyone can help me in this issue and what to do or where to check I will be very grateful. I’m desperate for any clues guys, and this is one car you don’t wana mess around and investigate. Anybody who faced this earlier in such late model their advice is much appreciated.
Got some clues that it might be the AMP, but also heard that it’s a programmable part. I don’t know whether the same part if removed and fitted again to be programmed or new parts only to be programmed. Plzzzz help. This was chit chat with someone I met the other day.
Sincerely yours,
MOE
Post #512710 21st Apr 2019 9:08am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
To be honest. The best thing to do is check the fuses first. It could be something as simple as that. If that doesn't solve your issue, come back and let people know. Then others can start to make suggestions. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #512720 21st Apr 2019 10:32am
GGDR
you can try a battery reset. Details in the wiki.
Worth testing your battery too.
. Cheers, Greg
Post #512721 21st Apr 2019 10:35am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
isnt the flashing power button a symptom of a dodgy bluetooth module? 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #512722 21st Apr 2019 10:42am
mohammed abood
Hi guys,
Thanks for every one's reply. I have checked the fuses, their all fine.
For the blinking matter it always blinks from before so an indicator that the radio is on and ready to use.
Any more clues plz. Big Cry
Post #512760 21st Apr 2019 5:23pm
Grofus
Water ingress in the left rear cubby hole. All the electronics are in there. Check pin connections and the circuit boards for water damage and clean as needed. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #512813 22nd Apr 2019 12:50pm
mohammed abood
Hi every one for the concern of.mositure from the cubby no worries cause we don't have such a high moisture like Europe specially these days and even though my car stays in covered garage.
Guys do u thing the same problem of the bluetooth like in 2007 edition might be happening in my case. Cause I have the fiber optic cables in my car too.
What do u think everyone....plz advice.
Post #512852 22nd Apr 2019 8:12pm
Grofus
It will cost you nothing but a small amount of time to find out. Do the bypass as desribed in wiki.
If it works you have your answer. If not, revert it back. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #512865 22nd Apr 2019 10:28pm
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
Mine did the same and a battery reset sorted it out 2011 Stornaway Grey 5.0SC Autobiography
Post #512878 23rd Apr 2019 7:42am
mohammed abood
Guys just a question plz,
For the battery reset, I how to do the battery reset thing.
A lot of people put there own ways there if any one who knows a proper way to do then,
I will be very greatful. Also bare in mind somhting.....there is a tag under the hood showing
An icon for removing the battery and says 120 sec. What does it mean like the car will lose
its programming after 120 sec.
And even though what type of memory will be lost. Like radio channels and all .ok engine data calibration for balancing and economy where in normal
cars computer gets it from start up. Plz advice guys like how to do and what would be lost and does it need reprogramming from the iid tool or what plz help.... Big Cry
Post #513021 24th Apr 2019 12:24pm
mohammed abood
I'm very sorry also for messy paragraphs cause writing from the phone sometime it's not easy... Crying or Very sad
Post #513022 24th Apr 2019 12:27pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
unlock the car, open the bonnet -- leave the car for 10-15-20 mins until all system have gone to 'sleep'
Disconnect the battery +ve and -ve -- then hold the cables together to 'short' the system -- 30 seconds to 1 minute should be ok, reconnect and away you go!
You will have to re enter date and time on your clock Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #513027 24th Apr 2019 12:49pm
mohammed abood
Hi everyone,
Bro thanks for ur message but do u mean literally shortening the positive and negative together....really ....like sorry but I never heard any one done this earlier to any car. I mean see any system in any car will have internal charge even if it's a little charge so shortening might if it's not frying the board it might cause a damage to it. See capacitors and some of the components will save the charge. So this will heart those components. See this is as far as I know....if you have done this procedure previously to ur car or any one else plz advice.
I'm sorry but I wanted to clarify and make sure and once again thanks for ur reply. Very Happy
Post #513038 24th Apr 2019 1:50pm
Bushy30
Yes -- short the cables together -- don't short the battery terminals!
That is the standard procedure Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #513041 24th Apr 2019 1:51pm
mohammed abood
Bro one thing more plz kindly,
From ur babilography I got to know ur car is a diesel type if I'm.not mistaken. My car is gasoline type.....would the internal systems in both be literally way different like as I know gasoline engines will have more computers for the ignitions and park controls and timings etc... and gadgets will be more then the diesel types....like as I know diesel engines are more mechanical types right ...just asking. Neutral Shocked
Post #513046 24th Apr 2019 2:03pm
