Home > Technical (L322) > Is it possible?
Witzend
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Is it possible?
Is it possible?
That the main dealer could update my vogue TD V8 MY2008 software with the wrong spec?
The reason I ask is that The invoices for all services and repairs from the main dealer since I have had the vehicle state the vehicle as HSE, All previous bills etc from previous owner state Vogue as does the V5.
After the last service I noticed that the Raise, Lower and Access messages were not showing in the dash notification area, Also the exterior temperature was showing 20 degrees centigrade on a freezing December morning.
The “free vehicle health check” flagged up a cart load of work that needed doing so I arranged for most of this to be done and delivered my vehicle at agreed date and time. I was having trouble with the battery, so told the service agent about it and also the problem with the dash notification area.
Long story short, the work was done including battery, but they said they couldn’t get the notifications to show on dash despite restoring software to before they did the work. Although it shows the raise lower and access on the 4X4 info screen it’s not the same and things need to be put right.
A couple of weeks ago I bought the IID Tool and first job was to plug in and read fault codes.
These in particular caught my eye as they were logged while at the main dealer.
AAM - AUDIO AMPLIFIER
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
( on 18-12-2018 00:44:44 at 81388 mi )
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
IPC INSTRUMENT PACK
U0248-87 (2F) Lost communication with remote driver utility module - Bus signal/message failure - missing a message
( on 18-12-2018 00:43:24 at 81388 mi )
VIM - IMMOBILISER
B1B01-87 (2E) Key transponder - Bus signal / message failure - missing a message
( on 18-12-2018 04:41:41 at 81388 mi )
When I scanned the ecu’s these values were returned
5 updates available and 6 values where no assembly exists, surely these should have been flagged at dealer and rectified?
AAM-Audio Amplifier
Latest Version
ACM-Audio System
Update available
ATCM-Terrain Response
Latest Version
BPM-Body Processor
No update found
CDP-CD Player
No assembly exists
DSM-Driver Seat
No update found
FBH-Fuel Burn.Heater
No update found
FEM-Navigation
Latest Version
HVAC-Heat / Cool
No update found
IPC-Instrument Pack
Update available
LCM-Light Control
No update found
PAM-Parking Aid
No update found
PBM-Parking Brake
No assembly exists
PCM-Engine TDV8
Latest Version
RAIN-Rain Sensor
No update found
RCM-Airbag
Update available
RLM-Suspension
Update available
SASM-Steering Angle
No assembly exists
SCLM-Steering Lock
No update found
TCCM-Transfer Case
Latest Version
TCM-Transmission
Update available
TEL-Cell Phone
Latest Version
TMC-Traffic Message
No assembly exists
TVM-Television
Latest Version
VDM-Vehicle Dynamic
No assembly exists
VIM-Immobilizer
No assembly exists
Also MPG is Shocking, trip computer is showing between 6 and 13 mpg, depending when I reset it.
Any help greatly needed and appreciated.
Thanks in advance,
Witzend (literally).
Post #512317 17th Apr 2019 6:16am
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Now I'm no expert on the l322 yet, but if they changed the battery then it will throw a number of errors. Not sure why they wouldn't have reset them though.
Post #512593 19th Apr 2019 5:09pm
Those fault codes can safely be disregarded, tend to pop up regardless of whether everything is working OK or not, unless you have identified a specific problem in that area. Not related to you issues.
Of interest for some ECU's - updates available -RLM suspension ? Instrument Pack ?
Your issues are all pointing to a problem with the central nervous system of the car - battery / BCU / EAS .
Post #512604 19th Apr 2019 6:39pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
My Range Rover is much older than yours and is of BMW vintage. When I got her home I kept popping out to keep checking on her, as you do..... as it was getting darker it was then that I noticed that the interior light was on.
It would go out when I opened the door but would go on when closed the door, completely the opposite to the way it should have acted. There were also other odd things like switches not working, suspension not working properly and the dash reporting the doors were open when they were, in fact, closed.
I thought it was in travel mode but after prolonged and intense conversations with GAP I found that my car had actually been ‘updated’ with the wrong software. It was running software designed for another model, so in response to your question, yes it is possible that your car could have been updated to the wrong model of car’s software.
I was lucky, GAP downloaded the correct software to my IIDtool and I updated the BCU and everything has been fine since.
Good luck in your investigations Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #512620 19th Apr 2019 9:11pm
Danwilderspin
Out of curiosity how did you get it to show an update was available or not? I don’t seem to have this on mine? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531268 17th Oct 2019 6:32pm
