Home > In Car Electronics (L322) > Different DVD on each rear screen
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Does anyone know if this is possible? I know there’s a DVD changer in the boot but is there any other other than the sat nav disc? With the headphones it would make sense to have 2 different films on, 1 for each passenger.
It’s a 2007 so has the early touch screen
Post #512318 17th Apr 2019 5:40am
Witzend
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hi, the DVD player I have in the boot, left hand side is for the sat nav on my 2008.
6 CD auto changer in top glove box and my DVD player (single disc) I think is aftermarket fit behind and more or less under centre console.
Hope this helps.
Post #512327 17th Apr 2019 7:23am
Full Fattie
I seem to have a slightly different set up although with yours being a 2008 I’m surprised they’re different.
6 CD changer in the upper glove box
6 DVD changer in the boot
Sat Nav DVD player below the changer in the boot
Post #512333 17th Apr 2019 7:35am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I'm not actually sure of the exact answer -- but I suspect not -- you could probably do TV and DVD to differing screens -- my thoughts are simply this -- a 6 DVD changer will have a cassette for 6 DVD's -- but unlikely to have anything more than one reading laser Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #512336 17th Apr 2019 7:49am
Full Fattie
I had a think about it and i couldn’t see how it would be possible either. When you’re on the RSE screen in the front there’s options for TV, DVD and a few others but crucially there’s only 1 DVD option. Other than putting another DVD changer in I can’t see how I can do it.
I could use the rear inputs with the 3 plugs but I don’t have a 3 plug output on the iPad.
Post #512338 17th Apr 2019 8:01am
Witzend
Hi Full Fattie,
Just checked mine, just the dvd for the sat nav disk in the boot, blue tooth module above that, however there is a space under the sat nav dvd where it looks as though a 6 Disc DVD player could sit.
Post #512339 17th Apr 2019 8:01am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I'm sure you could separate 1 of the screens from the main DVD system & then couple it to a separate source eg iPad / tablet etc. You'd need to leave the existing power to the screen rather than just cut & separate everything. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #512353 17th Apr 2019 8:58am
mjdronfield
The DVD player will only play one disk at a time, so no.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #512391 17th Apr 2019 4:37pm
mjdronfield
You’d prob need a lightening to HDMI lead then an HDMI to RCA converter to get the iPad into the AUX input.... but I’ve never tried it.
Can’t you just mount the iPad? And use separate headphones? Screen will be better, as RSE is not HD.
Save a load of faffing..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #512393 17th Apr 2019 4:41pm
Full Fattie
Yeah I think that’s gonna be the easier option. It’s a bigger screen too
Post #512525 18th Apr 2019 3:42pm
fin
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
For anyone reading this who want to connect something to the rear screens, be aware you cannot just buy a HDMI to RCA to make it work like the below
You need a real converter, something like the below
Post #512739 21st Apr 2019 3:00pm
