Home > In Car Electronics (L322) > Bovee 1000, what am i doing wrong |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Nothing as far as I can see, though as I'm not an apple user I wouldn't know, other than I've read some folk say you must have at least 1 track in iTunes.
14th Apr 2019 9:30am |
Steve67 Member Since: 22 Nov 2016 Location: Essex Posts: 18 |
Hi, thanks. I have many iTune songs just doesn’t seem to connect. The phone mutes as if its playing through some source, but now I’m thinking the cable could be at fault. |
14th Apr 2019 9:41am |
Sounds like it could be the case, anyone around you with a working cable? Current: 2011 FFRR Vogue SE 4.4 TDV8
14th Apr 2019 10:28am |
Ive tried the cable direct to my iPhone, and it works ok. Track listing and full function from the steering wheel. So now I’m stuck. Is there something else the tech people know I should try |
14th Apr 2019 10:42am |
Sounds like the bovee then, could you plug it and the cable into someone else's RR Current: 2011 FFRR Vogue SE 4.4 TDV8
14th Apr 2019 11:16am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2656 |
You have to pair the phone with the bovee unit, into Bluetooth,you should see it mate |
14th Apr 2019 11:18am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3829 |
Obviously you have to pair phone as others have suggested but as the Bovee doesn't recognise Spotify playlists (at least mine doesn't) I always have to set it playing on the Phone and then the Bovee just takes control Geoff |
14th Apr 2019 11:33am |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 |
Maybe it doesn’t like the music, please can you post a picture of you trying to play Spandau Ballet instead? |
16th Apr 2019 5:13am |
Ha ha ha ha , thanks pal I’ll try some culture club. Can you recommend a good one from them. 😂😂 |
16th Apr 2019 7:26am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I’ve just fitted an Amazon Echo Input and I stream Spotify that way. I just tell Alexa to play a certain track or station. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
26th Apr 2019 9:57pm |
