Home > Technical (L322) > Transfer box neutral message, suspect ECU |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 |
Following with interest as i had the same problem. Refurbished shift motor solved the problem.
11th Apr 2019 10:44am |
Judo Member Since: 24 Nov 2016 Location: Melbourne Posts: 14 |
Update...
13th Apr 2019 9:43am |
If you get an occasional message, I would probably still be looking at the potentiometer in the shift motor assembly. If you've searched this you'll see you can't buy just the pot which is unfortunate, but if it gets worse you can cut it open and have a go at repairing it if you're a DIY type person... Also if I'm anything to go by, you should always check fault codes and perform troubleshooting 101 before cutting anything open!! -Justin 2006 Vogue Td6 |
13th Apr 2019 9:47am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Plenty for sale on UK eBay:
13th Apr 2019 10:00am |
Chris.Gr Member Since: 19 Apr 2019 Location: Kifissia Posts: 7 |
Any update cos have the same brb? |
21st Apr 2019 5:49pm |
brb ? (be right back) .
21st Apr 2019 7:00pm |
I found a workshop and parts supplier here that had a second hand ECU. They posted me an ECU and I tried fitting it just before Easter only to discover it doesn’t fit. Very similar but the sockets for wiring looms are in a different order on the ECU. The looms are basically an exact size from 2 different sides of the ECU housing so they don’t reach to the positions on my new ECU. Have to wait another few days until they’re open again and see about swapping it.
21st Apr 2019 10:39pm |
