![]() | Home > Technical (L322) > Any Ideas Please Possible Faulty Injectors |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Yes - do a leak off test
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
Aren't the compensation values telling you that actually 1 & 6 are closest to zero and optimum.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi I was under the impression that anything over a reading of 2 was a sign of overfueling? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I’m no expert, but if it’s got to compensate loads, doesn’t that indicate an issue, as mentioned above?
This is a head wrecker I was told that any reading over 2 was an unhealthy faulty or dirty injector so why am I getting readings of over 600 on the other 4. Bearing in mind at idle I get all same 4 cylinders being 2 3 4 5reading over 600 and cyl 1 reads 2 and 6 fluctuating from 0 to 2. The reads I have submitted images for are at a steady run of 40MPH consistent for 5 mins. Could this be a wiring loom issue rather than injector? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
This came up when I did a google search.....
Suppose if you need to prove if it’s a loom issue, you’d maybe need to swap injectors round and see if the issue moves the injector orvstays with the loom. 2011 Range Rover Vogue SE 4.4 TDV8
