Home > Technical (L405) > L405 oil lever sender showing nothing
highfellzippy
United Kingdom 2015 Range Rover Autobiography SDV6 Montalcino Red
My oil level is inoperative on dash
Is sensor inside the sump or external 4.4sdv8
Post #511409 9th Apr 2019 6:16am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
It’s internal and a major job to get to.
Post #511410 9th Apr 2019 7:02am
GraemeS
The sensor is external on the TD/SDV8 whereas internal on the TD/SDV6.
Edit: Internal in the L405, external in the L322 version of the engines.
Post #511411 9th Apr 2019 7:04am
Red Merle
It’s internal on mine.
Post #511412 9th Apr 2019 7:20am
GraemeS
Well that's a backwards step! Do you know when it was moved inside?
Correction to my earlier post - the sensor is inside for all L405 4.4 TD/SDV8 whereas the exact same sensor is outside on the L322 version of the engine.
Post #511418 9th Apr 2019 7:46am
DrDill
I had this issue. Major job. Was sorted when it went in for 2nd year service. I am sure the dealer said it was a known issue
Post #511610 10th Apr 2019 9:01pm
