Home > Maintenance & Mods (L322) > Restricted performance message
Andy
Chaps I get this message in the exact same spot driving home. It’s so weird. It doesn’t do it anywhere else!
I can go for days without the message but as soon as I leave work and turn left then right - bang- there it is. Must be something in the air!
IID tool keeps saying manifold absolute pressure bank A. I’ve cleaned both MAP sensors. To be honest they were as new to look at. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511192 7th Apr 2019 9:02am
Did you try searching ?
It’s a fairly well documented error message.
The usual cause is a split turbo hose - which is a cheap and easy fix - and there is a good write up here - that’s likely the best place to start Thumbs Up
Post #511195 7th Apr 2019 9:09am
Andy
Yeah I’ve done loads of searches on it and tried everything. Hoses are both fine although I’m told there are two more. It’s making a fluttering noise as well.
The main point of the post was to highlight why it seems to pop up at the exact same location every time! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511197 7th Apr 2019 9:20am
I guess you’re doing something different.... accelerating, turning, going up hill ? Or maybe the car is just warm enough for something to happen ?
Post #511198 7th Apr 2019 9:39am
Nick591
If you are holding the accelerator pedal in a constant position (as in accelerating or going up a hill) try varying the pedal position slightly every few seconds and see if it still does it? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #511246 7th Apr 2019 6:02pm
