Home > For Sale & Wanted > [SOLD] Land Rover red anodised aluminium gear paddles
cliffc
United Kingdom 2012 Range Rover Autobiography TDV8 Zermatt Silver
Used for 6 months. As new condition. Genuine Land Rover boxed - see part number. Simple fit in 10 minutes.
£170 post paid to UK address.
Post #510898 4th Apr 2019 4:01pm
Andy
There must be more to this than a 10 minute fit? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510954 5th Apr 2019 7:31am
verydisco
If you do it without taking the steering wheel off, it only takes minutes, 2 screws all in, 2 connectors.
Turn the steering wheel 90 degrees and work from underneath the steering wheel / from the pedal box to see what you are doing - or do it 'blind' sat on the seat, it's only 2 screws really.
It is all detailed in the February issue of LRO magazine, this plus the steering wheel and switch pack replacement procedure.
[url][/url] l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #510966 5th Apr 2019 8:43am
cliffc
Honestly that's all it took me Andy.
1) Rotate the steering wheel to gain access around the column shroud
2) Remove one torx head screw per paddle
3) Locate new paddle, clip electrical connector and re-fit torx screw
4) Repeat for second paddle
5) Then just play - no coding or set up required
Post #510967 5th Apr 2019 8:46am
Andy
So the steering wheel is pre wired for paddles then? I haven’t got paddle shift fitted but I’d like to have it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510978 5th Apr 2019 10:04am
verydisco
^^^These are replacement paddles, if you do not have plastic ones, you can not simply add them indeed.
They'll work for 8-speed Gbox L322 (2010-on) and all L405 RRs, L494 Sports, and Disco 5. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #510988 5th Apr 2019 11:37am
Andy
Ah. Makes sense now. For a minute there i thought it was a plug and play mod! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510996 5th Apr 2019 12:27pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
But not a 2011 5.0 S/C with the 6 speed, even though it has plastic paddles as standard?
Post #511084 5th Apr 2019 11:42pm
verydisco
it will work indeed, they're just not that common indeed. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #511111 6th Apr 2019 10:04am
