![]() | Home > Technical (L405) > L405 2018 low battery |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
I’m getting low battery messages at the moment (MY17) when I don’t drive it for a few days. Always starts though. I’m investigating whether the BlackVue DashCam, which is controlled by their ‘magic box’, which should switch it off the DashCam when the battery voltage drops below either 12.5V or 12V (you can select), is the cause. It consumes around 350mA when in park mode. MY23 D350 HSE
Discol Member Since: 13 Jan 2019 Location: Tyrone Posts: 2 ![]() ![]() |
Phil
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 916 ![]() ![]() |
Had the same problem with mine and the dealer said they'd fixed it and replaced the battery. All was well until about two weeks ago and I had the warning again on one occasion.
Chalky - out of interest what did you set the magic box settings to? MY23 D350 HSE
Here you are, here is a link to the dachcam settings. I think mine is 2-on,3-off,4-on and 5 off. All LR cars from 1984
Oops forgot the link!
Thanks. Changed mine to 12.5V but the BlackVue switches off when the engine stops which defeats the object of having the magic box. The change did seem to stop the low battery warning.
