![]() | Home > Technical (L405) > New sdv6 engine |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1039 ![]() ![]() ![]() |
If you’re doing lots of short runs then a diesel is probably not the best, I’d go petrol. |
Kasperss Member Since: 06 Mar 2019 Location: Manchester Posts: 23 ![]() ![]() ![]() |
I would agree that petrol is a better option for short distance driving but only if you can get corsa or fiesta. I have Audi s7 petrol and returns 16mpg in town so not an option for ffrr as would be close or worst to that, i still do longer journeys over the weekend so dpf and other things should clean. |
Just |
Just to add I will only keep this car for 3 years so any issues with engine wouldn’t be a problem as it will be under warranty. |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
It is no longer covered under warranty if you need additional oil changes due to the engine regularly stopping mid DPF regeneration cycle |
There is s big difference between the 6 and the 8 in handling and braking too. If you really must go diesel, try them both; many buy the 6 as they don’t think they need the extra performance. Relative performance is not that relevant, both can lose a license |
I’don’t think engine oil have anything to do with dpf filter, i have owned volvo xc90 diesel and audi a6 2.0 diesel all used on short runs and all service i have done was exactly as specified in service books not an single issue over 3 years of ownership. |
Okay, here goes...
I think the main problem with short journeys and oil chainge is the fact that engine is not heated to right temperature. Im guessing if i will buy service pack then i will be fully covered with no additional service cost or if im doing around 8k a year one more oil change over 3 yeats of ownership would still cost much less than runing petrol car with 15mpg fuel consumption.
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 ![]() ![]() |
There is no service pack option on the FFRR.
Yes p400e would be an option but apparently loads of issue with this system and it could be a very good option but in the future. |
I’ve only driven the new SDV6 for a few hundred miles, so my experience is limited.
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 910 ![]() ![]() |
Most reviews about the L405 I have read/seen, say the VSE V6 is the "Sweet Spot" of the range. |
I’ve read that too. It’s usually based on the fact that it’s quick enough and cheaper, missing the main benefits of the ‘8 (listed above) completely!
