Home > Technical (L322) > Went to start but just a click
dazza1983
Weird one this morning. Jumped in the car ready for work, pressed the starter to accessory position as I always do and then placed foot on brake and pressed the starter button again and all I got was a click no engine start?
Tried this several times. Went in sulking and told the wife. Went back out locked and unlocked the car and it started??
It was almost like I wasn’t pressing the brake pedal enough. But I was
Just a weird moment for the car or a known problem? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #510071 28th Mar 2019 9:16am
battery or the start of the starter failing...
Post #510072 28th Mar 2019 9:35am
Baltic Blue
Try switching the windscreen wipers on and off next time it happens, then try starting it again.
Please report back.
Post #510073 28th Mar 2019 9:38am
dazza1983
Thanks Stan,
Ill shall keep an eye on it then Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #510074 28th Mar 2019 9:38am
dazza1983
Please report back.
Mike.
Interesting??
Could you elaborate some? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #510075 28th Mar 2019 9:54am
Baltic Blue
The “clunk” then nothing is a very common fault.
Like Stan says, it is usually solved by replacing either the battery or the starter motor ( or both )., but I have read that switching something on, usually, the wipers, performs some form of “D C wetting”, where a small current flow is sufficient to clear the fault temporarily, but sufficient to allow the starter to function again.
It is just a theory, but it costs nothing to try. Thumbs Up
Mike.
P.S.
I suspect that burned contacts in the solenoid part of the starter motor is the real culprit.
Post #510081 28th Mar 2019 10:33am
dazza1983
Interesting theory.
If it happens again I’ll try that out Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #510082 28th Mar 2019 10:43am
Baltic Blue
The very act of locking and unlocking the car probably would in effect be the same, and “blow away” the fault., allowing you to then start the car.
Post #510084 28th Mar 2019 10:58am
dazza1983
Thanks mike Thumbs Up
Ill keep an eye on it, at least a strater or battery woulnt be the end of the world,
better than chasing some electrical problem... Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #510086 28th Mar 2019 11:07am
CS
My 2012 WM had exactly the same (battery fine but occasionally just click when button pressed) and it was cured by replacing the starter motor, it's a known weakness. Only Range Rovers since 1988
Post #510092 28th Mar 2019 12:39pm
