Home > Technical (L322) > Diesel/oil leak passenger side front uk
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
Hi my 3.6tdv8 has developed a leak on the drive way it’s the passenger side front under the engine
It looks like oil on the ground but when I got underneath the car and ran my finger along the sump tray it looks and smells like diesel I removed cover but can’t find we’re it is coming from any suggestions
Thanks in advance
Post #509809 25th Mar 2019 5:15pm
j_rov
Could be a leak off pipe from injectors.
Could be a loose connection on high-pressure line to an injector.
Just whip off the black cover and have a look. I had this and it just needed a new o-ring on a leak off pipe connector and a tweak up of a high pressure nut.
Mine was leaking down the LH side of block and dripping off gear box to bell housing joint. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #509876 26th Mar 2019 10:16am
Benner91
Cheers I’ll have a look tomorrow weird as it’s black but smells of diesel also mpg is down to 20 it’s normally 22.5
Thanks
Post #509962 26th Mar 2019 10:54pm
