Home > Maintenance & Mods (L322) > squeaking creaking noise?
stucart
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Noticed a creaking squeaking noise when travelling with window open from my '07 4.2 SC. doesn't do it over speed bumps its on mainly smoother roads, tried coasting in neutral and still there so not engine related, sounds like a dry pivot on some part of suspension think its rear but difficult to tell, any suggestions??????
Post #509792 25th Mar 2019 3:56pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Close the window? Razz Very Happy
I've heard it be anything from front ball-joints sounding like it's coming from the rear, to rear upper/lower rose joints, to subframe bushes.
The rose joint creak has been likened to an old pram. you may be able to douse the joints in a PTFE spray, this is obviously a temporary solution, but can help you identify the culprit by being systematic.
Sorry I can't be more definite than this but as I say I've heard sounds telegraphing around the vehicle. I've seen people on here poke a tiny hole in a ball-joint gaiter, flood it with spray and seal the hole with silicone, then drive round a bit to let it penetrate and see if it helps. Formerly happymadison1978
Post #509798 25th Mar 2019 4:24pm
stucart
:DThanks for quick reply
Just had a poke underneath with some PTFE spray on rear suspension joints see if it quietens it, as you say trial and error to try locate it, bloody annoying though!! Banging Head
Post #509802 25th Mar 2019 4:33pm
Stephen.125
Oh absolutely!
Nothing like wafting around in a luxury vehicle that sounds like an old camp bed! Embarassed
Good luck, let us know how you get on! Formerly happymadison1978
Post #509804 25th Mar 2019 4:54pm
stu1
On ours it was the rear hub upper and lower rose joints - easy job with the right tools Thumbs Up
Post #509807 25th Mar 2019 5:09pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
I had the old squeaky pram issue last summer. Would come and go depending on whether it was dry or damp weather and if I'd sprayed my rear bushes and rose joints. Convinced it was the bushes but my local indy identified it as the handbrake cable rubbing. Repositioned and insulated the cable and been squeak free ever since. Might be worth a check
Post #509826 25th Mar 2019 7:25pm
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
I have the same problem nearside rear, although mine does it on bumps at slow speed as well. I had the top and bottom hub bushes replaced a couple of months ago to try and cure it, but it still squeaks.
I also checked the handbrake cable after reading previous comments, but couldn't see anything obvious rubbing. Beginning to suspect inner suspension bushes as I can't really hear it with the window open. Wherever it is though, it's driving me mad! Banging Head David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #509828 25th Mar 2019 7:38pm
stucart
Don’t think it’ll be handbrake cables as mines got the electric version, not been out since sprayed it so who knows , might try local Indy see if they can pinpoint it.
Post #509839 25th Mar 2019 8:30pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Stu, its the bush on the rear suspension.. easy way to diagnose is to pump some silicone grease through the rubber. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #509964 26th Mar 2019 11:19pm
stucart
Any chance of a pic of which bush???
Post #510003 27th Mar 2019 1:32pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Any one with this problem in the North West can have the bush replaced at my mates garage as they made the tool for the job and it took just 45 minutes a side to do mine....message for details. Best to get bush, washer, nut and concentric bolt of some one like Dan though as they are hard to source individually....
Post #510085 28th Mar 2019 10:01am
Rear inner upper and lower wishbone bushes can also be a cause of squeaking .
Post #510088 28th Mar 2019 10:26am
