Home > Maintenance & Mods (L322) > DPF ?
Triumph72
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
DPF ?
I was trying to check my soot levels with my IID tool, but it was showing
as N/A.
I was under the assumption that my RR was fitted with DPF but after looking
around on here, it might be the case that it is not fitted to my model year
Can someone explain what to look for under the RR to tell if I have one fitted?
Max
Post #509765 25th Mar 2019 11:46am
number 6,
Post #509775 25th Mar 2019 12:54pm
rjff
Max
Trying to make heads or tails on fitment of a DPF is confusing Confused
But, I think manufacturers of cars designed (homolgated?) prior to 2009 were allowed to offer the option of fitting DPF at build. Vehicles homolgated after 01/01/2009 had to have a DPF and all vehicles registered after 01/01/2011 had to have a DPF. Thus a 3.6TDV8 would be alllowed the option of no DPF, so if that's your FF then it may not have a DPF. A build sheet should show the info. Perhaps try entering your vin into vindecoderz.com, mine shows up as having a DPF.
I'm listening for the whoosh as someone pulls the rug out from under my feet Mr. Green Cheers
Richard
Gap IIDBT
Post #509790 25th Mar 2019 3:53pm
Triumph72
Well I had a look and am glad to see that I don't have a DPF, according to Stans picture also had a look at
the vin coder website and it only mentions an Eco class exhaustа Euro 4, for emissions.
Cheers Max
Post #509803 25th Mar 2019 4:51pm
rjff
One less thing to worry about. Thumbs Up
hmmmm, but surely that's the whole point of a fullfat Mr. Green Cheers
Richard
Gap IIDBT
Post #509805 25th Mar 2019 5:03pm
Tomo676
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
I asked the very same question a few weeks ago. Mine is a ffrr 3.6 tdv8 and mine doesn't have a pdf !!! Thank God lol.
Post #510037 27th Mar 2019 8:27pm
Tomo676
Forgot to mention, mine is a 2010 model.
Post #510038 27th Mar 2019 8:28pm
Triumph72
Yes, it was nice to find out there was none on the car.
From what I have been reading, I think about 2010 was the final year that you could choose to have one or not.
who would have ticked that box?
My son drives a BMW Diesel and has had plenty of trouble with
the DPF on that car.
Post #510042 27th Mar 2019 9:33pm
Tomo676
More trouble than they are worth and very expensive when they get full up.
Post #510047 27th Mar 2019 10:03pm
kooky_guy
Triumph72, is yours a 3.6 or a 4.4? I thought all 4.4s had a dpf?
I might have to go and check mine... 2010 4.4 TDV8 Vogue SE
Post #510068 28th Mar 2019 7:40am
GGDR
Yes and no. With heavy research I had mine removed, cleaned and put back for around £200.
Quote:
My son drives a BMW Diesel and has had plenty of trouble with the DPF on that car.
Glad to hear it's not just me!
. Cheers, Greg
Post #510076 28th Mar 2019 9:12am
Triumph72
TD 3.6
Post #510080 28th Mar 2019 9:29am
