Home > Off Topic - Other Cars > Range Rover sport 2007 fault
fil b
England 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
My sport supercharged 2007 is developing a fault when going around a long right handed ie a roundabout, seems like the dsc is kicking in making a grinding sound and feeling like the car is braking on one wheel.would it matter if I switched the dsc off to try and see if it still does it. Any ideas please someone said it might be the yaw sensor
Post #509575 22nd Mar 2019 6:11pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi you will be better served on the sport forum. www.rrsport.co.uk Thumbs Up
Post #509577 22nd Mar 2019 6:38pm
Mikey
Alignment issue or steering Angle Sensor calibration
On some cars recently, we have found the plastic drive has come loose on the steering shaft, letting the calibrated values slip out of spec Thumbs Up
Post #509584 22nd Mar 2019 8:35pm
fil b
Thank you, I switched the DSR off and it was fine so it must be some kind of sensor.
Post #509783 25th Mar 2019 3:07pm
