Home > Technical (L405) > Airbag warning light?
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
This has recently come on in my 2014 L405. It went off in the warm dry weather but now is back. I'm goign to get it sorted but anyone encountered this?
Post #509374 20th Mar 2019 10:11pm
Many times with seatbelt pretensioners sir... Thumbs Up
Post #509384 21st Mar 2019 12:43am
palli
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Yes. Wiring loom under passenger seat became damaged because I fold the back seats down regularly and the fronts move.
Seems to be a fairly frequent problem from what I have seen. 2008 Vogue Black - gone
2012 Vogue SE White - gone
2016 Autobiography Blue - gone
2019 Autobiography Grey - gone
2020 SVAutobiography Red
Post #509474 21st Mar 2019 6:23pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Had mine come on recently - couldn't clear it with a fault reader, then it suddenly disappeared and hasn't come on again. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #509481 21st Mar 2019 7:49pm
Emperor Mong
Mine comes and goes too. Seems to be humidity related.
Post #509507 21st Mar 2019 11:52pm
AMD
Happened on my 2014MY intermittently. It was looked at by the dealers twice but they couldn’t find the fault, so never fixed. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #509602 23rd Mar 2019 9:00am
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
The workshop I sent my car to 'replaced a new connector for the air bag wiring.'
Thats what he told me and the warning light has not reappeared again. '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #514244 4th May 2019 3:53pm
Dinsdale
England 2016 Range Rover Vogue SE TDV6 Kaikoura Stone
Happened twice on my 2016 MY. Dealer said known fault in the wiring loom in the driver’s side A pillar going to that airbag. Replaced under warranty and nothing since. I personally would get it checked as it could really be a safety critical bit which won’t fire off in an emergency situation. BUT don’t simply get the fault cleared otherwise it can’t be tracked down.
Clive
Post #514621 7th May 2019 10:48pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Mine came on today ffs
Post #514626 7th May 2019 11:43pm
Gazm007
United Kingdom 2013 Range Rover Autobiography SDV8 Havana
newbie question regarding this. i picked mine up last friday but dont remember if the light was on but notice that the amber airbag light stays illuminated. should it do this (or is the light you guys are referring to a red light?)
thanks for your help
Gareth
Post #516739 28th May 2019 8:44am
Mr Tee
Yellow one which comes on with ignition.
Post #516740 28th May 2019 9:25am
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
I had this on my car over two years, on and off intermittently.
They dealer replaced seat belt pretensioners, and seat connectors,the amber light still came on.
Finally they did some sort of software update, and all is working now.
So ask about software update at your dealer.
Post #518538 15th Jun 2019 1:06am
Mr Tee
Well I’ve had the loom done and the damn light came on again . Back to see what’s what .
Post #575096 4th Dec 2020 7:49pm
jettec
Ah yes one year of no airbag light after mod carried out.
Where they remove a bit of foam pulling on wiring loom in drivers seat base cushion.
Took car in the other day , as idling at lights and car ran rough for a couple of seconds , like it was going to stall.
Then restricted performance flashed on dash and amber engine light stayed on.
Left car overnight a dealers, they carried out tests no faults logged for the engine light.
However diagnostics faulted airbag light that had come on. But disappeared in front of techs.
Car handed back with no faults recorded.
So even they cant explain what was going on, I think its haunted !
Post #575122 5th Dec 2020 12:05am
Mr Tee
Ghost in the machine ? Nothing left to blame ffs Mr. Green
Post #575127 5th Dec 2020 8:18am
